License expiry
Why does Leapfrog have to close all my open tabs without saving when the license expires.
Pisses me off. That should not happen if the session in renewed.
2
Hey @MichaelJMunroe,
LF should always ask to save in-progress work if the licence expires. I can follow up on why we have to shut the tabs but I assume it's because many tabs are associated with extensions that might not be checked out again on the licence renewal? ...but I should confirm that with our engineers.
Have you noticed a specific tab not saving information correctly ? I've checked the behaviour for calculations tab on block models and that seems to save work.
The only thing I can point out to try and alleviate some of your annoyance is that we do have a countdown in the bottom right corners of the UI that should show in red text to say that there's less than an hour, I believe, left until the licence expires. Again, please let me know if you don't get this warning.
Cheers,
Rachel
0 -
Hi Rachel,
I'm having a similar issue running a geological model, when the license expires Leapfrog closes everything without saving layout, scene view, etc. Even though the number of tasks is reduced, when I renew the license, all the processes will start from 0 again. I tried pausing the processing before the license expires, but once I get a new license everything starts from scratch again.
Any suggestions or recommendations to avoid this issue?
TIA
Laura0 -
Hi @LauraGomez, I don't currently have any workaround for you on this however I've asked our wider support teams to see if there's anyone else with a suggestion.
@MichaelJMunroe I did some digging and it turns out we did make some changes about how we warn people their licence is about to expire; the description I gave in the 3rd paragraph is therefore inaccurate.. I've raised this as an issue to further investigate and improve.
Categories
- 695 All Categories
- 100 Products & Software
- 11 Seequent
- 180 Leapfrog
- 336 Geosoft
- 11 GeoStudio
- 4 Developers
- Seequent Evo APIs
- 157 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
