About texture import in Mesh
Hello, anyone know how to import textures to a mesh?
Thanks
  • DavidWatkins
    DavidWatkins Posts: 48 Staff
    Hi @JoseMamaniVilca,
    You can either:
    - Drape a image on a mesh.
    - Import the mesh as an .obj with associated .mtl and image files.
    - Import the mesh as Maptek .00t and .ireg files (Maptek Link extension required).
    Regards,
    David
  • DavidWatkins
    I hope that helped, let us know if you are still having issues.
    Cheers,
    David
  • @DavidWatkins I am struggling recently with the obj import where when I import the obj it does not bring the texture mtl file in the project, it just brings in the mesh. I tried the obj export as jpeg, tiff png nothing seems to works. It worked for the previously, but since the 6.04 release it does not do it.
  • DavidWatkins
    edited July 2021
    Hi @GranthamOckhuizen1,
    Apologies, I didn't see your response until now. Can you please open a support ticket and we can assist you in determining the source of the problem. Does the exact same obj + image work in previous versions of Leapfrog?
    Things that usually trip up the process include:
    - Using non-relative file paths to the image in the .mtl file.
    - The .mtl file not being explicitly listed in the .obj file
    Thanks,
    David
Categories
