How to gat the sub-block index as metadata
Best Answer
Thanks for the feedback @GillesRoy,
I have added your comments and vote against the BM index metdata feature request.
For interest we will be adding trigonometry functions to calculations for the 2021 year-end release, so you may be able to apply those to your CRL calculations for rotated block models as a work around.
Regards,
David1
Hi @GillesRoy,
How would you like to use the sub-block index values in your calculations or filters? We might be able to suggest an alternative if we understand the expected outcome.
Thanks,
David
0 -
Hi David, I want to export a BM result to an external software. Block must be 3x3x3 . The import is done using the C R L, it did not work using the block centroid XYZ. BM at 3x3x3 is a +90M cell model. In LF i built a 12X12X12 (best according to KNA) with sub-block 3X3X3. I am able to tag the LF 12X12X12 with fake calculated C R L that fit the 3X3x3. But I can only do that for a no rotation BM, the BM is rotated to 315 deg. So I need the sub-block index to calculate a C R L out of a 12X12X12 sub-block model that match a 3x3x3 model.0
Categories
- 678 All Categories
- 85 Products & Software
- 11 Seequent
- 173 Leapfrog
- 332 Geosoft
- 7 GeoStudio
- 2 Developers
- Seequent Evo APIs
- 155 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
