Borehole water tables (points) in cross section layout
Hi all,
currently I have imported borehole water tables as points into Leapfrog. As far as I know, there is no possibility to visualize them in a fence section layout. Is this correct? Does anyone know a bypass solution? Currently the only way would be to visualize them as intervalls (i.e. saturated and unsaturated) but that would mean some effort.
Any suggestions would be appreciated
Thanks
Thomas
Hi Thomas,
Here's what I came up with: change the points table to an interval table with very narrow intervals at your water level (e.g. from 16 to 16.001). Then calculate z-value of the midpoint for your water level elevation, and "label" the interval in cross section view. It's not exactly pretty, but it works.
Cheers,
Kip1 -
Thats a great idea! And it is much better (and less work) than the saturated/unsaturated approach. Thanks a lot! Really appreciatedThomas0
Categories
- 692 All Categories
- 97 Products & Software
- 11 Seequent
- 179 Leapfrog
- 335 Geosoft
- 10 GeoStudio
- 4 Developers
- Seequent Evo APIs
- 157 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
