Font size
Hi,
How do i change the deualts font size, for example in striplogs for the different data columns?
Hi Mathias,
Where to look depends on which specific fonts you want to change, so i'll offer a few suggestions. You might want to look in the following areas of the Strip Log tool:- For the Hole name (Collar name) or Depth Tick labels, check the "Hole Trace" tab. Look for "Size (mm)".
- For the Scale bars, or the numeric labels on the Data Strips themselves, click the "Define" button to open the "Parameters" dialog. Most of the font size options are found here. Look for "Text size (mm)".
0 - For the Hole name (Collar name) or Depth Tick labels, check the "Hole Trace" tab. Look for "Size (mm)".
Categories
- 711 All Categories
- 113 Products & Software
- 11 Seequent
- 191 Leapfrog
- 339 Geosoft
- 10 GeoStudio
- 8 Developers
- 1 Seequent Evo APIs
- 160 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
