Log Display Support
Hi @AmitPatel, We can create a similar strip log with profiles displayed with a log scale. Here's an example:
The option to display profiles or bar plots with a log scale in a strip log only exists when you have From/To data. If you are working with point data (measurement at a depth), like a LAS file for example, you need to export your data and create from/to channels and reimport the data in the correct format.
1. Export your point data.
Database > Export CSV > All channels > Include dummies = yes > Include channel names = yes >Include line names as data = yes.
2. Open CSV in Excel.
3. Copy the DH_Depth column into 2 new columns (DH_From, DH_To).
4. Add a zero to the top of the DH_From column so it shifts all the numbers down one cell.
5. Import your new CSV to your drillhole project as From/To.
When you recreate the strip log with a profile or bar plot you should now see a log option:
Community Manager0
Categories
- 694 All Categories
- 99 Products & Software
- 11 Seequent
- 180 Leapfrog
- 335 Geosoft
- 11 GeoStudio
- 4 Developers
- Seequent Evo APIs
- 157 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
