Print map to layered PDF
How can I print maps from Geosoft/Target to layered pdf?
My pdf's are flat.
My pdf's are flat.
HI @ElenaMusienko
First go to Map > Export... and in the output format dropdown, select Portable Document Format (*.pdf).
Ensure the Region to Export is set to Full Map, unless you only want the viewed portion of the map exported.
Click OK and in the next dialog, check the Save Layers in PDF option.
Click OK and your exported PDF file should contain layers.
Cheers,1
Categories
- 695 All Categories
- 100 Products & Software
- 11 Seequent
- 180 Leapfrog
- 336 Geosoft
- 11 GeoStudio
- 4 Developers
- Seequent Evo APIs
- 157 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
