Error 154: parse error at "GRID3D"
CarolineTweedle
CarolineTweedle Posts: 3
edited August 2018 in GX Developer
Hi all,
I have just moved onto version 9.4 of GX developer, and now, upon running the gxc compiler, I get the above error.
It isn't my code, as the same happens on the supplied Geosoft source code. The grc compiler appears to run correctly, I have checked the "all.gxh" and "grid3d.gxh" files and they appear to be normal - I can't see anything obvious that would cause a parse error.
Has anyone encountered this and can you help please?
Thanks
Caz
EDIT: I have commented out the include line for grid3d and Multigrid3d which allows it to run
Categories
