Import GIFs into ROCKCODES
Hi @AtanuBanerjee The only way to set the colour and patterns for your rock codes is manually through the Edit Rock Codes dialog. But once it's created, you can set it as your default Rock Code file, and if you consistently log your core with the same rock codes, it's something you probably only have to do once. You can even share the rock code csv with others who use the same codes.Community Manager0
Thank you for your valuable feedback.0
Categories
- 695 All Categories
- 100 Products & Software
- 11 Seequent
- 180 Leapfrog
- 336 Geosoft
- 11 GeoStudio
- 4 Developers
- Seequent Evo APIs
- 157 GX Developer
- Early Access Programmes
- 1 Oasis montaj Field EAP
