Automation of activities
Dear colleagues,
I have been working in ANP - Brazil National Agency for Petroleum where we have some licenses of Geosoft Oasis Montaj.
It is my first time using the GX Developer API. Firstly, I need to automate some steps which are:
1. Read a gdb file
2. Delete channel(s)
3. Generate the X and Y channels by Latitude, Longitude and a current Datum
4. Create a Fiducial channel
5. Sort some channels
6. Export the modified data to the xyz format or asc format.
As I will develop the solution using C#, I looked into the gxnet\examples and gxnet\src directories in order to find examples to the implementation. As a result, I have found some samples which I am not certain if they will suit the solution. So, I put them bellow in accordance to the indexes above:
3. Directories CoordSysWizard\NewPCS and Database\SplitLinesOnXY
4. Directory Database \SplitLineAtFid
May you send me examples or just write me which ones I must study in order to achieve the solution? I need to develop the solution urgently.
I look forward to receiving an answer.
Thanks in advance!
Best regards,
Gustavo Xerez
1. Read a gdb file
Thanks in advance!
Best regards,
Gustavo Xerez
Dear Gustavo.
It seems like all of those tasks seem more suited to be solved by simply scripting your working steps, rather than programming a GX. Just an idea.
