Import DXF error
ScottWillers
I'm currently converting a project from one grid to another (NZMG - NZTM) and have an 'Import failed' msg. The same process I'm using works for polylines but not meshes.
Export - Convert in and save in QGIS - Re-import in LF
Does anyone know what's going on here?
Hey,
Not sure about the type of data you're trying to import, but I've encountered this same problem recently and it was failing because I was trying to import it as a mesh and not as a polyline.
I'd suggest trying importing as a polyline if it's not a solid object.1 -
Hi @ScottWillers. DXF files cover a multitude of formats including polylines, points and DXF blocks. Do you know the source of the file, and for certain that it is a triangulation?
I agree with @OyundalaiEnkhAmgalan . I would trying importing as a polyline. I suspect you're working with a string file.1
