How can I separate my created volumes in parts?
I created a geological model. Now I would like to know the volume [m³] of every geological layer laying inside the building excavation. How can I get this data?
  • I'd recommend creating a Combined Model. You can use the Design or Meshes folder to import your building excavation; then create a new Geological Model, using the excavation object to create your intrusion surface (specify the Lithologies as Inside and Outside). You will then be able to create a Combined Model of these two models, which will allow you to compare lithologies inside the building excavation with those outside. You will also be able to view the properties of the combined output meshes to see the volume of your units inside your excavation.
    Combined Models (seequent.com) This page on the Leapfrog Help website has more information about Combined Models.
