What's the best way to create polylines for selected lines only
Dear all,
I have a shapefile for multiple fault traces. I want to extract those traces to individual polylines for fault modeling.
I know I can delete useless polylines after I extract the entire file to polyline, or I can save individual lines by edit shapefile. However, both ways are very time-consuming.
Is there an efficient way to do this work?
Thanks!
Thanks!
Hi, There is no direct path for doing this with such a large shape file. Just remember you can limit the size of the shape file you import by setting and selecting the clipping boundary on import.
The one option I might go with is to create an extruded mesh from the total polyline object. This will give you a single mesh with many individual meshes that are generated from each polyline that was in the file.
Then extract these meshes, and you can select just one at a time because these are identified as separate objects and rename it and extract, then repeat. This will give you a single mesh per fault. Just ignore those you don't want.
Regards
Keith0
