Importing texturized meshes
ErwannLebrun
I am trying to import an .OBJ file as a texturized mesh into Leapfrog (together with the .MTL and .PNG file). It works fine in other 3D softwares but Leapfrog does not import correctly the .PNG texture: it stretches and trims it instead. It is almost as if the way Leapfrog references textures for .OBJ files is different than any other softwares (is it?).
Any idea why this happens? Is there a limitations to how large the image must be (dimensions in pixels and/or size in Mb)?
Cheers
Hi @ErwannLebrun,
If you are able to share the .obj could you please open a support ticket so that we could have a closer look at it.
David
- 773 All Categories
- 171 Products & Software
- 225 Leapfrog
- 353 Geosoft
