Is it possible to create a cubic slice?
JamesBlack
I was wondering if there is a way to have 2 slices active at the same time, to cut a cube shape out of my ground model to show the geology in a specific area of the model.
Thanks in advance
Thanks in advance
@JamesBlack,
You can't have two active slices at the same time, but as a work around you could try a few possible work arounds:
- Evaluate your GM onto a block model and use the index filters to create a subset / sliced block model (dynamic slicing).
- Make a copy of your GM and add a lateral extent to its boundary using a polyline based on the area that you want to remove (limited to a single prechosen slice).
I hope that helps, Cheers
David
