Printing
Im tryin' to print my section map but in the printing view,it takes two pages.
When i print is not so good, could help me to fix it in one page.
Glever, once you create a map there is a physical size attached to it. You would have to recreate your section map at a larger scale so that the physical size fits within the desired page size.
To figure the new scale, in the Map Manager of your section map click on Base to set the units to the physical size of the map. Now if you move the cursor on your map along the bottom right the units will be in cms. If you would like your map on a single page recreate your map at a map scale that when in the Base mode the top right corner does not exceed the dimensions of the physical page.
I hope this helps.0
