Tiff Import
Hi I am trying to import a 32 bit GeoTIFF format file. The file has data values foreach cell and is effectively a grid. It loads into ArcMap no worries but I am struggling to get it into OM. Example files can be found here (they are quite large): https://www.pgc.umn.edu/data/arcticdem/ (scroll to the bottom for mosaic DEM's). Has anyone experienced similar issues?
@BrendanHowe I have had the same issue. Sometimes I can fix it by converting the TIF to 24-bit, but maybe that only worked because it changed the compression as per @NatalieGreen's suggestion? @NatalieGreen are 32 bit TIF's fully supported as that help article only lists up to 24 bit.0
