PDF from a map in a Python script
DaveHildes
in GX Developer
I am trying to make a PDF from a map in a stand alone python script - does anyone have any examples of how to do this?
I have tried the gxapi.GXPDF3D.export_2d() function and this does produce a pdf, but it is tiny. I don't understand how this function is supposed to works as there is no place to input a page size.
Any other options or suggestions?
Dave
import geosoft.gxpy as gxpy import geosoft.gxapi.GXPDF3D as PDF3D gxc = gxpy.gx.GXpy() PDF3D.export_2d('test.map','test.pdf',0,0,0)
Dave
Hi Dave,
Another option might be in the geosoft.gxpy.map module in the documentation.
If you have a geosoft map file you can open it create a map object by using the open method.
Then if you use the image_file method you can save the map to an image. There are various formats. PDF does not appear to be one, but you could save it as a PNG (default) and then use another python library (such as img2pdf) to convert the PNG to a PDF. The image_file method lets you set the size of the map in pixels so hopefully will overcome the small map issue.
I hope this helps.
Cheers
Sean1 -
Thanks Sean, good idea. Just skip the PDF3D_export_2d() by using another python library to get the pdf out. To be clear, when I said the function was making a tiny PDF I didn't mean just a small one, but rather just a file name. The page size was as close to a zero page size as I imagine a PDF will allow (like 0.04 X 0.04 inches)1
