def rungx() makes my script fail
DaveHildes1
in GX Developer
I understand that I need the rungx() if I am running a python script from Oasis. But I don't understand this result:
This code works:
Dave
This code works:
import geosoft.gxpy as gxpy import geosoft.gxpy.grid as gxgrd #def rungx(): # raise Exception("This is not an Oasis extension. Please run through a python interpreter.") gxc = gxpy.gx.GXpy() xyz=[(450.,10.,100.),(60.,25.,77.),(50.,8.,80.)] gridName = "test.grd" grid = gxgrd.Grid.minimum_curvature(xyz,file_name=gridName,overwrite=True)while this code fails:
import geosoft.gxpy as gxpy import geosoft.gxpy.grid as gxgrd #def rungx(): # raise Exception("This is not an Oasis extension. Please run through a python interpreter.") gxc = gxpy.gx.GXpy() xyz=[(450.,10.,100.),(60.,25.,77.),(50.,8.,80.)] gridName = "test.grd" grid = gxgrd.Grid.minimum_curvature(xyz,file_name=gridName,overwrite=True)So what is going on?
Dave
Sorry, copy/paste error. This code fails.
import geosoft.gxpy as gxpy import geosoft.gxpy.grid as gxgrd def rungx(): raise Exception("This is not an Oasis extension. Please run through a python interpreter.") gxc = gxpy.gx.GXpy() xyz=[(450.,10.,100.),(60.,25.,77.),(50.,8.,80.)] gridName = "test.grd" grid = gxgrd.Grid.minimum_curvature(xyz,file_name=gridName,overwrite=True)
All the code should be inside the rungx method for a montaj Python GX script. E.g.:
import geosoft.gxpy as gxpy import geosoft.gxpy.grid as gxgrd def rungx(): gxc = gxpy.gx.GXpy() xyz=[(450.,10.,100.),(60.,25.,77.),(50.,8.,80.)] gridName = "test.grd" grid = gxgrd.Grid.minimum_curvature(xyz,file_name=gridName,overwrite=True)
The exception code inside a rungx() method seems to be for a standalone script to not be unintentionally used as a Python GX script.0 -
Sorry the forum is messing up the code indentation. The intent was that all lines under def rungx should be indented.0
Thanks Jacques.
But my intention is to run it as a standalone script, so I had that exception code in there for exactly the purpose that you pointed out. But it fails as a standalone script unless I comment out the rungx exception section.
I have other standalone scripts where this works fine - it seems like it is the Grid.minimum_curvature that doesn't like the rungx exception section.
- 773 All Categories
- 171 Products & Software
- 225 Leapfrog
- 353 Geosoft
