contour
PankajKumarDas
in Geosoft
Hi @PankajKumarDas, there's no contour setting that controls the density of the labels.
You can try adjusting the scale of your map. The scale can really impact how your contours appear. A smaller scale can make your contours less dense over all, which may also help with the labels.
You can easily change the scale of your map by drawing a base map and changing the scale in the first dialog.- Map tools > Base Map > Draw Base Map.
- Redraw your contours after changing the scale.
Community Manager0 - Map tools > Base Map > Draw Base Map.
