Create a Menu to Run Python Extensions
I'm starting in Python and I could not create a menu by following the procedure below: Can anyone help me? I want to call hello world on the menu at oasis montaj
Hi Michel,
Did you place your "myPython.omn" menu in
c:\Program Files\Geosoft\Desktop Applications 9\omn?
It should be in
c:\Program Files\Geosoft\Desktop Applications 9\user\omn
and it will silently cause problems if you have the same menu in both.Technical Product Manager0 -
You will also need to load the menu by selecting Settings > Manage Menus and going clear to the bottom to User menus to select your menu. Your menu won't appear in this User menus list in the case I described above.Technical Product Manager0
I also have an issue with this. Following the steps in the tutorial (and above) i get an error message that reads
"unable to load "mypython.omn. The menu is either empty or you are not licensed to use this menu."0
- 672 All Categories
- 80 Products & Software
- 10 Seequent
- 170 Leapfrog
- 1 Developers
- 154 GX Developer
