Print map to layered PDF
ElenaMusienko
in Geosoft
How can I print maps from Geosoft/Target to layered pdf?
My pdf's are flat.
My pdf's are flat.
HI @ElenaMusienko
First go to Map > Export... and in the output format dropdown, select Portable Document Format (*.pdf).
Ensure the Region to Export is set to Full Map, unless you only want the viewed portion of the map exported.
Click OK and in the next dialog, check the Save Layers in PDF option.
Click OK and your exported PDF file should contain layers.
Cheers,1
