Extracting channel data as strings (.NET)
With string data use the VV methods. Create a string VV and read the data from a database channel into the VV.
Note that database reads will convert to the target VV type, so this will also convert numeric data to strings (formatted using the channel format style), in case that is useful.0 -
Late reply but, how would you setup with the Constant to create a VV as a string, I assume you use CVV.CreateExt() or CVV.Create() to create the VV.0
I'm interested in the answer to this question also. I don't see a string option in the Create and CreateExt constants.0
Below are examples on how you would create them.
in C#:using (var dbVV = CVV.Create(-GeoEngine.Core.GXNet.Constant.STR_FILE, 0)) { dh.GetDatabasesVV(dbVV); ... }
in GXC:GridNameVV = Create_VV(-STR_FILE, 0);
in Python:vv_agg = gxapi.GXVV.create_ext(-gxapi.STR_FILE, 0)
Joseph0
