depth-to sources methods: tilt angle and Euler deconvolution
Hello everyone
please I am a beginner on Geosoft. I have used a satellite gravity data whose resolution is 5000m (2.5 arc minutes). I have three questions:
1. Considering a flying height of 5000 m and a suitable structural index, will the results from the Euler method give me solution depths below ground surface?
2. Are the solution depths obtained from Tilt angle ( reciprocal of horizontal of the tilt angle) to be considered as depths below surface?
3. Please how to proceed in both cases to obtain reliable depths below surface?
thank you in advance
@GaudPouliquen please provide me an answer0
Hi @DarrenAndrews would you mind giving me an answer plz0
