Error 154: parse error at "GRID3D"
CarolineTweedle
Hi all,
I have just moved onto version 9.4 of GX developer, and now, upon running the gxc compiler, I get the above error.
It isn't my code, as the same happens on the supplied Geosoft source code. The grc compiler appears to run correctly, I have checked the "all.gxh" and "grid3d.gxh" files and they appear to be normal - I can't see anything obvious that would cause a parse error.
Has anyone encountered this and can you help please?
Caz
EDIT: I have commented out the include line for grid3d and Multigrid3d which allows it to run
Caz
Hi Caz,
Apologies. I missed merging a fix made in the master branch to the 9.4 branch. I just fixed the release on Github: https://github.com/GeosoftInc/gxc/releases/tag/v9.4
Jacques Beaurain2
