Get and change map object colormap to custom one through GX
Hi.
Since changing colormaps(for example for comparative profiles) is a chore in Geosoft, I am scripting a GX to do it.
Changing one colormap that is not in the standard folder and a zone file is about... 15 clicks? More?
Anyway.
Pretty much first GX.
I got a list of my maps and I filtered it for the ones I need
def rungx():
project = gxpj.Geosoft_project()
gxc = gx.GXpy()
gxpj.user_message("Maps","Maps: {}".format(project.project_maps))
mapnames=project.project_maps
IP_maps=filter(lambda x: 'IP_' in x, mapnames)
for map in IP_maps:
gxpj.user_message("Maps","Maps: {}".format(map))
with gxmap.Map.open(map) as gmap:
with gxview.View.open(gmap, "data") as v:
BUT I can't find anything in the documentation that allows me to get the grid and its colormap, nevertheless change it.
Sadly, the tutorial here
https://geosoftgxdev.atlassian.net/wiki/spaces/GXD93/pages/108528042/2D+Views+and+Maps
also says nothing about how to do a colormap
Any help?
Anyway.
def rungx():
gxc = gx.GXpy()
for map in IP_maps:
Any help?
With this code I have been able to get the maps loaded so far
import geosoft.gxpy.gx as gx
import geosoft.gxpy.map as gxmap
import geosoft.gxpy.view as gxview
import geosoft.gxpy.group as gxgroup
import geosoft.gxpy.agg as gxagg
import geosoft.gxpy.grid as gxgrd
import geosoft.gxpy.viewer as gxviewer
import geosoft.gxpy.project as gxpj
import glob
p_colormap=Geosoft\\Grids\\Profiles\\IP_bell.zon'
filtterm='IP_'
gxc = gx.GXpy()
path='Geosoft\\'
maplist=glob.glob(path+'*.map')
IP_maps=filter(lambda x: filtterm in x, maplist)
for maps in IP_maps:
#print(maps)
with gxmap.Map.open(maps) as gmap:
with gxgroup.Color_map(cmap=p_colormap) as g:
Here is where I don't know howto change the color map0 -
Hi Dietmar,
Groups in map views that visualize grids are called aggregates in the API. You can get a list of these groups in a view via the group_list_agg method. Each layer in the aggregate has a color map.
Currently changing the color map is not exposed via the gxpy API but it is available in the lower level gxapi API via set_layer_itr. You can get at the lower level objects via the gxitr property (undocumented) of a gxpy.group.Color_map instance and the gxagg property of an Aggregate_image.
Jacques Beaurain
