Unable to do interp on X-sections
We constantly get "adding polygon failed because it is self-intersecting" errors anytime polygons intersect at the same point using snapping.
Also when we try to export sections to ArcGIS to have more control over shapes and avoid the above error, the plan view is exported but not the map grid, and nothing in the section data fram is exported to the MXD either.
Hi, I'm going to send your question to our support team. Someone will be in touch about the error you are getting while digitizing.Community Manager0
