Create section from Line
Good day.
I want to ask you, can I with target arcgis, to create section from selected line. And this line must be draw before It. For example it will be shape file or graphick line.
IN the 3D Analyst for creating section, first draw lani in the dem or tin, and then we can see section getting from this line.
Tnank you very much.
Hi @AlesgerMammedov, If you have the line displayed in your active data frame as a shape file, try using one of the Define on active data frame options when you click the Section button. This will let you digitize the section location from your map and set the Section location automatically.
Community Manager0
